Eric_C_Boston
- Eric
- Apr 16, 2021
- North Shore, MA, USA
- 2021 Ford Mustang Mach-E RWD ER
- Retired Software Engineer
![United-States Country flag](https://www.macheforum.com/site/misc/flags/shiny/32/United-States.png)
If you have a program to read the extended PIDs, like Torque Pro, you can compare the LIN readings to the CAN readings. Toque Pro can also log PIDs.
I noticed LVB Current can be zero with a non-zero LVB DCDC LV Current when the DCDC Converter is powering the 12 Volt Bus, but not charging the battery.
Code:
LVB Age,LvbAge,0x224027,INT16(A:B),0,65535,Days,726,,,1
LVB Current,LvbA,0x22402b,A-127,-127,128,Amps,726,,,1
LVB DCDC Enable,DCEn,0x22483d,BIT(A:0),0,1,,746,,,1
LVB DCDC HV Current,DCHVA,0x22483a,A*0.1,0,25,Amps,746,,,1
LVB DCDC LV Current,DCLVA,0x224836,A,0,255,Amps,746,,,1
LVB State of Charge,LvbSoc,0x224028,A,0,100,%,726,,,1
LVB Voltage,LvbV,0x22402a,A*0.05+6,6,20,Volts,726,,,1
